Where to configure server-side environment variables/secrets?
Hi team,
I’m building an application (Next.js-based) that uses server-side integrations with OpenAI and the Teable API.
The app needs these variables available through process.env on the server runtime:
  • TEABLE_API_URL
  • TEABLE_APP_TOKEN
  • TEABLE_BASE_ID
  • OPENAI_API_KEY
Normally the chatbot can generate the code correctly, but in this session it says it does not have access to:
  • custom environment variables / secrets management
  • runtime redeploy/restart tools
I do not use Vercel or Render directly — the app is hosted entirely inside Teable.ai.
Questions:
  1. Where do I configure server-side environment variables/secrets?
  2. Is there a built-in “custom environment variables” or “secret manager” UI?
  3. Can the App Builder chatbot normally configure them automatically?
  4. How do I restart/redeploy the hosted runtime after adding secrets?
  5. Are these variables exposed securely only to server-side routes (not browser/client)?
Important:
I do NOT want to:
  • hardcode secrets
  • store them in Teable tables
  • expose them with NEXT_PUBLIC_*
  • commit them into source code
The app currently needs:
  • OpenAI API access
  • server-side Teable API access
  • runtime process.env support for Next.js API routes
Any guidance/screenshots would be greatly appreciated. :blush:
Hi @Alex,
Thanks for the detailed explanation.
At the moment, App Builder does not have a separate Environment Variables panel for Teable-hosted apps. We are already discussing how to support server-side environment variable management more properly.
We also noticed that Cuppy is currently a bit conservative when handling requests related to environment variables or sensitive values, and we are working on improving this behavior.
As a current workaround, App Builder supports importing code via ZIP, and a root .env file in the ZIP can be read into the app’s custom environment variables.
Please refer to our documentation here for the detailed requirements and steps:
Since code import merges into the existing project and may overwrite files with the same path, we recommend testing this first in a new simple app before applying it to your production app.
