Teable on touchscreen laptop
Just a quick heads-up in case someone faces the same quirk as me. I’m using a self-hosted community edition of Teable with my team and my laptop has a touchscreen. I thought editing the tables in Teable was a bit clanky but I just found out that on non-touchscreen laptops, Teable workflow is much better. I Just disabled touch UI on Chrome for my Teable to show proper tools and features for me to work properly. I’m not a technical person, so I don’t know if this is an intended behavior of Teable. Anyway, Thank you for an awesome product and I hope this info is useful for some people as I was searching for Teable settings for hours before I searched how to disable touch on Chrome instead.
Thank you.
Rax
Thanks for your feedback! We really appreciate it and will keep optimizing the operation experience.
