🔌 Teable now has an official MCP server: use your data from Claude Code, Codex, Cursor and more
Hi everyone! We just shipped an official MCP server for Teable. You
can now use your Teable data from Claude Code, Codex, Cursor and other
MCP clients, with your own permissions. No API key needed: the client
asks, you approve once in the browser, done.
Claude Code
claude mcp add --transport http teable https://mcp.teable.ai/mcp
Then run /mcp, pick teable and choose Authenticate.
Codex
codex mcp add teable --url https://mcp.teable.ai/mcp
codex mcp login teable
Cursor and others: add https://mcp.teable.ai/mcp as a remote MCP
server. The setup for each client is in Settings → MCP.
It’s an early release, so please give it a try and tell us what works, what doesn’t, and which client you use.
We’re collecting feedback right here in this thread. Reply below
with anything you notice: a bug, a tool you wish existed, a client
that won’t connect, or just what you built with it. Thanks!
I’m trying to connect Teable Cloud to ChatGPT Work on the web using Plugins → Add custom MCP server, OAuth, and https://mcp.teable.ai/mcp.
On my first attempt, the OAuth opened Teable’s sign-in page. After I signed in with Google, ChatGPT reported “Authentication succeeded, action discovery failed.” On later attempts, the redirect no longer showed the Teable sign-in page and appeared to reuse the first account. Recreating the plugin and retrying with a clean browser session still gave me the same discovery error. Also, When sign-in window did appear, it was a sign-up window. I had to click on sign-in to reveal sign-in window. However, this was no good. After this sign-in, a redirect url was selected, and then ChatGPT window appeared with the notice, “Authentication succeeded, action discovery failed.”.
The plugin can appear in ChatGPT, but it exposes no callable Teable tools in the chat. My test was read-only. I asked it to list my spaces, projects, tables, fields, and record counts where available.
Has your team tested this endpoint through Add custom MCP server in ChatGPT Work? If so, is there a known issue or a specific OAuth setting I should use?
ChatGPT connection icon did appear in Developer Tools >>> MCP, btw. Still no tools discovery from ChatGPT end. Was I suppose to fill in my credentials in the ‘Sign-Up’ window for any specific reason?
Hi Alex,
Thanks for the detailed report. It made this much easier to trace.
Short answer: yes, we’ve tested https://mcp.teable.ai/mcp through Add custom MCP server in ChatGPT, and other ChatGPT users are connecting and calling tools through it successfully right now. No special OAuth settings are needed: leave the authentication on OAuth and ChatGPT registers itself automatically.
What we saw on our side for your account:
  • Your OAuth sign-in worked every time. ChatGPT received a valid token with the full set of permissions.
  • After that, ChatGPT connected to our MCP server, and our server returned the tool list normally. There were no errors on our end.
  • However, ChatGPT never went on to call any tool. So the “action discovery failed” message is coming from the ChatGPT side, after it has already received the tools.
Since you’re on ChatGPT Work, the most likely cause is a workspace setting. Could you check these?
  1. Ask your workspace admin whether custom MCP connectors / developer mode are enabled for your workspace, and whether this connector’s actions are allowed. Some workspaces restrict actions, especially ones that can write data.
  2. If you can, try the same steps with a personal ChatGPT account (outside the Work workspace). If it works there, that confirms it’s a workspace policy.
  3. Before you retry, remove the old Teable connector in ChatGPT and add it again, so you start from a fresh connection.
Best,
The Teable Team
