i accept the recommended model of Open Ai gpt 5.5 , but i wish to switch back to Anthropic , is there anyway i can do so ?
Hi @mikaelteoh ,
Thanks for sharing this. May I ask why you’d like to switch back to Anthropic? At the moment, the model can’t be changed manually, but I’d like to better understand your reason so we can record the feedback properly.
i find that , its not as smart as Anthropic, it keep say it will start to work but nothing happen , after i demand few time , then it only start working , and it take longer time compare to Anthropic . The token may consume less , but overall experience and performance is not ideal
@mikaelteoh Trust me, with our latest optimizations, GPT-5.5 is much smarter now.
As for token consumption, feel free to give it a try. It’s not just slightly lower. We hope credits are no longer something you have to think about, so you can simply enjoy your data journey.
Thank you so much for being so thoughtful and looking out for us. It’s wonderful to see the progress and optimizations your team has put into this!
Regarding token consumption and model selection, I’d like to suggest giving the autonomy completely back to the users by allowing them to choose freely. Ultimately, users should be responsible for their own decisions and the associated costs. Giving them that control provides great flexibility for different project needs. Thanks again for your consideration!
@mikaelteoh Thank you for your suggestion. We’ll take this into consideration.
Same here, I logged in yesterday and found out that we don’t have any other option to choose from. Please give us the option to choose as previously set. you can mention or recommend that gpt 5.5 consumes less credits and it is smart and place the rest in another drop down tab and let us choose if we want to use other ai generators. I have other AI accounts and they have the defualt option which consumes less credits and usually does a good Job but we still have the other ones if needed. Thanks
@Charle We recently updated the model selection because GPT-5.5 currently offers stronger overall intelligence, significant cost advantages, and a more user-friendly experience. We made this change with the goal of letting users use Teable freely without worrying about credits.
That said, thank you for your suggestion and detailed feedback. We understand that you’d like to have more model options. We’ll keep this feedback in mind and continue to evaluate it, but we don’t plan to change the current model selection setup in the short term. I wanted to set the right expectation upfront so it doesn’t affect how you plan to use the product.
Please rest assured that we’ll continue optimizing Teable in the most user-friendly and high-quality way possible, and we’ll always work to make Teable the best experience in its category.
Thanks again for your understanding and support.
