Save Apps as Templates
PLEASE let us save Apps as templates.
Save App as Template, so I don’t need to rebuild it completely. Even if I tell Cupy to make an exact copy of the App, it builds it slightly differently and some bugs - that I already solved in the old app - are present again.
Make a good App once. Re-use it with different datasets. In my case: I have different clients, and want to showcase candidates to them. It would be good to be able to “clone” or “open” a templated app instead of starting all over again for each new client.
Hi @steph47dh7 ,
Thanks for the detailed use case.
This has come up before in our community. There’s an existing discussion on a Template Marketplace that’s worth checking out: https://community.teable.ai/t/template-marketplace/193/2?u=leo
In the meantime, if you don’t need to share the app publicly, the quickest workaround is to duplicate the base. When you copy a base, all resources tied to it — including Apps — are copied over as well. That way you’re working from a clean clone of your polished setup, not rebuilding from scratch.
Hi @Leo ,
thanks for your soon reply. I will check out duplicating a base. However, I think this is not an ideal process, because one will have 10s or 100s of bases.
Re the other discussion: this is something different. I do not want to publicly share the templates. I only want to “clone” or “save” my own app.
Example: i created an app for a client, where I present candidates AND where we can collarobare in the app.
This app is very useful also for other of MY clients. So i want to re-use this as an internal template.
One thing worth noting on the Share approach: the link doesn’t have to stay open permanently. You can enable it, save a copy yourself, then turn it off — so it works fine as a one-off.
On duplicating: it depends on whether your App is bound to a specific table. If it is, duplicating the base is the cleaner option since everything stays connected. If the App isn’t tightly bound to a table, duplicating just the App should carry over the logic, data reads, and actions as-is.
That said, the best path forward really depends on how your App is set up. Could you share a bit more about your structure — for example, is each client’s data in a separate base, or all in one? That’ll help us point you to the right approach.
