New Teable Agent: Super Intelligent at a Much Lower Cost
We’ve made a major upgrade to the Teable Agent engine — dramatically improving AI Chat’s ability to handle complex tasks, while reducing credit consumption to just 20% to 3% of previous levels—or even lower.
What’s New
  • Credit consumption drastically reduced — in our complex task benchmarks, efficiency improved 5–30x, or even higher.
  • Enhanced large file processing — AI Chat can now handle dozens of Excel/CSV files at once, or PDF documents up to 100 pages.
  • Significantly improved complex task capabilities — for example, provide your Airtable API key to AI Chat and migrate an entire base to Teable:
    {Your Airtable Token} Use this Airtable token to read all content and create a migration plan to Teable. If the data volume is large, please use the maximum write throughput available.
    Tip: Remember to delete your token after the migration is complete.
  • Model switching support — AI Chat now lets you switch between models, including Opus, Sonnet, Haiku, and MiniMax.
  • Uninterrupted AI Chat sessions — fixed internal server error disruptions so conversations stay smooth from start to finish.
  • Clear task timing visibility — each conversation turn now shows execution time at completion.
  • Credit usage visibility — tap the bottom-right three-dot menu to view credit consumption once a conversation ends.
  • Lean, faster conversation UI — redesigned interface is more compact, responsive, and focused on high-value information.
  • Parallel sub-task execution — support for sub-agents enables concurrent workflows and faster completion of complex tasks.
  • CuppyClaw is here — access the Teable Agent directly in Slack, Telegram, and Feishu.
  • Prompt while running — you can now send follow-up instructions even while the Agent is still executing.
  • Granular credit transparency — added a detailed credit usage breakdown in Settings → Billing.
Our Thoughts
We believe that after this update, Teable Agent has reached a top-tier level in the industry in both credit efficiency and intelligence. You can now use Teable AI Chat with much greater confidence to describe your needs and build what you want.
Combined with our at-cost, zero-markup credit pricing, Teable is built to make every credit go further: More use. More power. More gain.
What’s Next
  • Support for skill usage and management.
  • CuppyClaw support for WhatsApp.
  • V2 database engine upgrade for faster, more powerful data processing at larger scale.
  • Login authentication system with support for email, Google, Teable, and more sign-in methods.
  • Support in-app AI features in App Builder.
  • A series of product capability enhancements.
Important Notes
  • During AI conversations, occasional session interruptions may occur. As a temporary workaround, start a new conversation or click “Clear Chat” in App Builder. This is a known issue and will be fixed within 1–2 weeks.
  • During AI conversations, Question Cards may occasionally display incorrectly. This is a known issue and will be fixed within 1–2 weeks.
  • The New Agent Engine is currently in Beta — there may be rough edges. We’re committed to continuous iteration toward a flawless experience. If you encounter any issues, please share your feedback and we’ll address them promptly: New Agent Engine Feedback Form
