Would be very nice
Hi! Thanks for the suggestion. We’d love to understand your needs better.
Could you share a bit more about your use case for a native Pabbly Connect integration? For example, what workflow are you trying to build?
Some many uses - to connect with other Apps & software - Pabbly Connect is very user friendly and powerful
Hi, thanks for the interest! To help us evaluate a Pabbly Connect integration properly, could you share a bit more detail?
Which specific apps/services are you trying to connect with Teable through Pabbly?
What does your ideal workflow look like? (e.g., “when X happens in Teable, do Y in another app”)
How many workflows/automations are you planning to run?
Are you currently using any other integration tools with Teable (Zapier, Make, n8n, etc.)?
Is there a specific limitation you’re hitting today that’s driving this request?
The more context we have, the better we can prioritize and find the right solution for you. Thanks!
I second this request!
Agreed! Having a direct integration with Pabbly would be helpful - one simple idea is passing leads and their contact info into a CRM (whether its a custom built one within other vibe coding tools or something like NinjaPipe) or using it to pass leads into Encharge within an elaborate marketing strategy. And no, personally not really using those other tools over Pabbly since its a lifetime deal so its the go-to for some of us. After this, then add Make.
Teable is very powerful when it comes to data processing, including exchanging data with third-party tools. In many cases, as long as you can clearly describe what you want to achieve, Teable AI can help make it happen.
For most third-party tools, data exchange with Teable doesn’t necessarily require a dedicated connector, including tools like Zapier or Pabbly.
You can simply describe the workflow you want to Teable AI, and it can help set up the data flow. Or, if the third-party tool has API documentation, you can provide that to Teable AI and describe what you want to achieve.
For example, you could describe something like passing new leads and contact info into a CRM, or sending leads into Encharge as part of a marketing workflow.
Feel free to give it a try and share your feedback with us. That would also help us understand where a dedicated Pabbly integration might still be useful.
