Migrating MS Access to Teable & Google Workspace integration
Does Teable support migrating from MS Access (2013), creating input screens, and syncing with Google Workspace?
Yes. You can migrate from MS Access to Teable, generate input screens with natural language, and connect with Google Workspace via Zapier/Make (Webhooks/HTTP).
Watch the demo for the data migration and input screens
See the first scenario ‘Talk to Build Databases’ and second scenario ‘Talk to Build Apps on Data’ in our launch video: https://youtu.be/xfYeJ2YM1zk?si=qb2lCuCyO_fY-bOt
1. Regarding Data Migration
Move your MS Access data into Teable with either path:
  • Option A: Export your Access tables → import into Teable.
  • Option B: Upload your data and use Talk to Build Databases to map/import it using natural-language prompts.
2. Regarding Input screens
Describe—in plain English—the form you want (based on your existing tables), who will use it, and how it should look. Teable will generate the input screen in minutes. Try it and share feedback on the result.
3. Google Workspace integration
Connect via Zapier/Make using Webhooks/HTTP for two-way sync.
So far, you won’t see a native Teable app on Zapier/Make yet—it’s already on our roadmap—but the approach should work; it just requires a bit of simple code configuration.
