I created my Kanban view and sorted my data using the single select field [e.g., To Do, In Progress, Done].
Now every time I create a record in a specific column/group [clicking the + button at the bottom of the desired column/group, e.g., To Do], instead of automatically assigning the single select value of that column/group, it brings the record to the uncategorized column/group.
Yes, that’s exactly the issue. I’ve reproduced it on my side as well. Creating a record from a specific Kanban column should automatically assign the corresponding single select value, but currently it falls into the uncategorized group instead.
Hi @LadyDerpynette , just to follow up — I filed a issue on the same day you reported this (April 16). You should have received an email notification about it; if you didn’t see it, it’s worth checking your spam folder.
Once the issue status changes, you’ll be notified right away.
