We have identified what appears to be a bug in Teable’s cookie consent implementation when a public shared form is embedded in a cross-site iframe.
Affected page: https://academiementorat.ca/candidat
Embedded form: https://app.teable.ai/share/shrOiOoiODqUHwmWpF6/view?theme=light&embed=true
Symptoms:
Reject All and Accept All buttons are visible and enabled.
Both pointerdown and click events register successfully.
Clicking either button does not dismiss the banner.
Browser localStorage and sessionStorage are functional.
No failed HTTP requests were detected in the recorded Network log.
Suspected root cause:
Inspection of the production JavaScript delivered by Teable shows that the saveConsent implementation writes the teable_consent cookie using SameSite=Lax.
Because the form is embedded on a different registrable domain, that cookie may not be accessible in the iframe context. I use GHL (GoHighLevel), for more context.
This is preventing visitors from accessing our embedded application form, or using it but getting frustrated that the tech isn’t quite working as it should and then questioning if the form even works.
Thank you.
