Is there a way to publish an app internally so it is only accessible to registered users or specific accounts? I want to build apps that only I (or a small group) can access—not public or visible to everyone.
If this is supported, could you share how to set it up (private/internal publish, invite-only, domain restriction, roles/permissions, etc.) or point me to the documentation? If not, are there any recommended workarounds to keep an app private?
Hi Nilson,
There’s no built-in native authentication for published apps yet — by default, anyone with the link can access it. But you can:
Build a login gateway in App Builder
You can create a simple username/password access control layer directly within App Builder. A real example of this approach is the SDR Cold Call Manager template ( Explore templates built with Teable | Teable ) , which demonstrates exactly how to implement this kind of login natively inside your app.
