Introducing Teable 3.0 — The AI Spreadsheet for Business
Teable 3.0 is a major step forward for real business work with AI. You can build 100% business-fit AI workflows and custom apps, creating a true AI business data hub. With Teable, you can also connect any system or migrate data into one place.
Whether you’re a small business or an enterprise, Teable helps your team become truly AI-native.
Watch the Teable 3.0 launch video: https://youtu.be/rI9w7p17ukQ
What’s new in Teable 3.0:
  • Connect & Migrate Anything — Move from Airtable, spreadsheets, files, and other systems into Teable. Data, table structures, attachments, and linked records can be migrated into one AI-ready workspace.
  • Complex task capabilities — Teable can now handle long-running tasks, such as handle dozens of Excel/CSV files at once, or PDF documents up to 100 pages.
  • Super Automation — Automate custom workflows that fit your business, from contract expiration reminders to weekly sales reports, Slack updates, approvals, and operational processes.
  • Custom Apps 100% business-fit — Build dashboards, booking pages, portals, internal tools, and business apps directly on top of your data.
  • Business-aware Email Agents — Generate and send personalized follow-up emails in bulk using your customer data, business context. Personal inboxes and unsubscribe links are supported.
:raising_hands: Support our Product Hunt launch
If you like what we’re building, your upvote would mean a lot to us: https://www.producthunt.com/products/teable-4
Congrats on 3.0. Do you have instructions somewhere how to connect other things besides Slack and Airtable? Thanks!
Hi @lisa , The connection process is fully AI-guided, with Teable AI providing step-by-step instructions throughout:
  1. Type / in the Teable AI chatbox.
  2. Select Connect Everything.
  3. Enter the name of the platform you want to connect.
  4. Describe your requirements, such as:
    • What data you want to import
    • What actions you want to perform on the data
Teable AI will then provide the appropriate instructions and guide you through each step of the setup process.
