If I build an app under the Pro plan and then stop paying, will the app still work?
Yes—the published app will continue to work.
  • Access
Whether you’re using the cloud or a self-hosted version of Teable, after you Publish and get the app URL, the app stays accessible via that URL—it won’t stop working even if your plan expires. Your app remains available to you and your users as long as you don’t delete or disable it.
  • Editing
If you want to continue editing, you’ll need to stay on the Pro plan or higher—then you can rename, duplicate, or iterate on the app anytime.
  • Data flow
Anything your users create or edit through the app is written in real time to the linked table(s) you connected during setup. For data usage limits, see teable.ai/pricing.
