How do I add more seats to my self‑hosted Teable Pro license?
  1. What’s the recommended upgrade path?
  2. How is the extra cost calculated?
  3. Will the change cause any downtime?
  4. Can we later reduce the seat count if our team shrinks?
  1. Open License Settings
    • Go to Settings → License or visit https://app.teable.io/setting/license.
  2. Adjust the Seat Count
    • Change the number of seats from your current total (e.g., 6) to the new total you need (e.g., 8).
  3. Review Prorated Pricing
    • Teable automatically prorates the cost and shows the exact price difference before you confirm.
  4. Confirm & Pay
    • Complete the checkout flow. Your new license certificate is generated instantly and applied without downtime.
  5. Start using the extra seats
    • The additional seats are available right away. Simply invite new users or assign the seats as needed.
  6. Can we later reduce the seat count if our team shrinks?
    • Currently, reducing (shrinking) seat count is only supported for the Cloud edition.
    • For Self‑Hosted licenses, once a license key is issued, it cannot be modified or downgraded due to technical constraints in our licensing system. We appreciate your understanding.
