Hire Frelancer to install self-Stoarge Amazao
Hello
I would like to hire someone to do a full installation of self-hosted system
We are using a amazon server
The issue that I got now are
  • The building app module is not working
  • The upload of csv database is limited
Evertime I run building app module I got server error
I tested the “CRM Lite” version (only Customers + All Bookings) and it still fails with the same Internal Server Error. That suggests it’s not caused by “too many tables/fields”, but a general App Builder issue on your instance (service/config/permissions/bug).
To find the real cause (not guess), you need one of these:
If you have server/admin access (recommended)
Check the Teable backend logs around 14:16 Europe/London for a 500 on the app builder endpoint. The logs will show the exact exception (DB error, auth issue, feature flag, etc.).
Tell me how Teable is deployed and I’ll give the exact command:
Docker / Docker Compose?
Kubernetes?
Hosted / managed?
If you don’t have server access
Send your admin this info:
Any “create app” request returns 500, even with only 2 tables
Exact time: 2026-03-10 14:16 Europe/London
Base ID: bser07fmheEFu8ScGup
Workaround (until App Builder works)
You can still use the standard Teable UI as a CRM (views, filters, linked records, forms). I can help you set up:
“Customers (CRM)” view
“Bookings pipeline” view
“Customer 360” view (lookup/rollup fields)
automations (follow-ups, tagging, notifications)
Which deployment is it: Docker, Kubernetes, or hosted?
Task completed
Add context
Paste or drag and drop to upload here
Describe what you want to do
gpt-5.2
So I would like to hire
Thank you
Hi! Since this topic is a continuation of our discussion in I give up self-hosted, let’s keep the conversation in that thread so everything stays in one place.
