I have implemented storage in boxes through individual tables with lines representing the samples and a column with A1, A2, A3 for the location. I would love to adapt the data to show a more location centric view and represent storing and taking out of samples.
A new view that is set up as a grid. Similar to gallery but with fixed with and heigt e.g. 10 by 10. Clicking on on cell opens the information of the sample stored. Storing and taking out of samples could be implemented with a button?
Our Lab (and labs) in general might be happy to use this to track and log all of their samples in freezers.
@maniok_getragen3b Thanks for sharing the details. I understand the goal: a location-centric grid (e.g., 10×10) where each cell represents a slot, and clicking a cell opens the stored sample record, with simple actions for storing/removing samples.
A quick suggestion to try in Teable: on the right side, in the AI Chat and describe your requirement directly. AI Chat will automatically activate Build App, and App Builder should be able to generate a grid-style interface that matches what you’re looking for.
If you give it a try, I’d love to hear how it feels and whether it fits your workflow. And if you run into anything or want to refine the layout/logic (store/remove actions, slot status, validations, etc.), we’re happy to support you further.
