I worked with AI to describe a project management system that needed 17 tables. Teable aborted after generating 8 tables. I cannot figuire pout how to have teable continue to generate the tables. Tha apps I generate go beyond the classic “internal app” use case and require large numbers of tables.
Thank you for your interest. We are working on improving the performance of the agent to support more complex long tasks. It will be able to handle more tasks and we will update this in this quarter.
Bieber - thanks for your quick reply. I dev line-of-business apps and have ben very successful with lovable - I have many apps developed. Don’t like supabase as it is a resource hog. Do like postgres very much.
Is there any way now or on the horizon that you see a way that I may be able to migrate lovable aps to Teable?
We don’t currently support migrating Lovable apps to Teable. We believe there may be a viable path, but we need to research the best approach before committing to a timeline.
In the meantime, you can keep your existing Lovable apps running and route their data to Teable using Lovable’s chat-based setup: set Teable as the destination, provide your Teable API token, and the target table URL. New apps can be built directly on Teable for an integrated stack.
