Hi team,
Apologies if this has already been asked, but where can we submit suggestions? For example, the ability to resize the “Credit usage summary” pop-up to full screen.
Hi team,
Hi! You’re welcome to share suggestions right here.
Out of curiosity, what’s making the full-screen view useful for you — is there specific information in the credit usage summary that’s hard to see at the current size? And are there other parts of the experience that feel limiting or unintuitive?
Hi @Leo, I would say it’s more of a “nice to have”. I have large monitors (32” and above) and the pop-up only takes up about 50% of my screen, which is why I’m asking.
On that note, talking about the experience:
• Is there a way to see a list of recently run automations? Similar to the credit usage
• The same for files - having a file list, folder, or section would be nice (sort by name, size, date, etc.)
Hi @Alex , thanks for the suggestions!
The full-screen pop-up and automation history are both noted — I’ve added them to our feature request pool. We’ll keep an eye on how much traction they get from the broader community.
For the file list/folder view, could you share a bit more about your use case? For example, are you looking to browse files across multiple bases, or manage attachments within a specific table? Knowing the specific workflow you have in mind would help us better understand the need.
