Downloading generated zip files
Hi team :waving_hand:
The App Builder successfully creates ZIP archives inside the workspace, providing internal paths like:
/home/agent/workspace/…/project.zip
However, I can’t find a way to actually download those generated ZIP files to my local machine.
Is there currently:
• a download/export functionality for generated files?
• a workspace file browser?
• a way to expose generated artifacts/assets for download?
• or another recommended workflow for exporting generated projects/files (not code)?
At the moment the only workaround seems to be asking the chatbot to print files manually one by one (which is not ideal, obviously).
Would appreciate any guidance :slightly_smiling_face:
Hi @Alex,
Thanks for the detailed write-up.
For downloading the app code itself, you can use the built-in download feature — see: https://help.teable.ai/en/basic/ai/app-builder#download-code
For other generated files (like ZIP archives created during a session), there isn’t a dedicated download/export mechanism or workspace file browser at the moment. This is something we’re actively considering.
That said, I’m curious — could you share a bit more about your use case? What kind of projects or files are you generating as ZIPs through the App Builder? That context would help us prioritize this on our end.
just ask chat to give you zipped files inside a table with version information. it will build a table where you can easily locate and download your files.Sometimes you need to tell again to place zipped folders inside download column.
