Console code inspector for editing AI applications (context addition)
Hello, dear developers!
Console code inspector for editing AI applications (context addition). I am sure that this will help a little with the visual editing of the AI code that has been created.
There is now a wonderful feature for creating web applications using AI. But, as I mentioned in another request for a new feature, it is difficult for non-programmers to edit code manually. It is also difficult to describe a small part of the code (for example, a container, header, widget, form field, icon, button, etc.) in the AI dialogue chat so that it understands exactly which element I want to change without affecting the rest of the code. Therefore, I suggest adding a visual highlighting (selection) feature for parts of the code to be added to the AI chat context (currently, only tables and their views can be added to the context).
A general example would be how the code inspector works in the browser console.
Or you can see how this is implemented in other vibe coding platforms.
Lovable
base44
Google Firebase Studio
Thank you for your feedback. This request has been well received, and we have logged the issue. We will notify you promptly of any subsequent updates.
