Capture location data from phone in form
AirTable seems to have a extension which I’ve not tried Collect GPS Location and IP address in Form for Airtable
I’m also aware that PostgreSQL on which Teable is based has https://postgis.net
A new location (lat/long) field type. Capture location information in a form submission.
Capture location of when a form was submitted.
Find the a record or multiple records based on location proximity.
Hi @mibstar ,
You can leverage Teable’s new Talk to Build Apps on Data feature to create a form that captures the user’s location as part of the submission.
For example, you can try a prompt like:
Help me create a form based on this database, I hope the location field can capture the submitter’s location data.
Here is a demo screenshot of a successful verification.
