FIXED
Hello Teable Support,
I’m encountering an Authority Matrix compatibility issue
The live Authority Matrix export contains these legacy disabledActions identifiers:
updateRecord
createRecord
deleteRecord
copyRecord
The current Authority Matrix validator accepts only the canonical identifiers:
record|update
record|create
record|delete
record|copy
When I try to save the Authority Matrix in the UI, validation fails with errors such as:
Validation error:
Invalid input at "tables[0].disabledActions[0]"
The CLI produces the same issue:
Invalid "deny" action "updateRecord" for table tbl47prG84ulbIycnOI.
Allowed: ... record|update ... record|copy
Both authority diff and authority apply --dry-run fail before producing an inspectable comparison. The UI also rejects the entire matrix when I attempt an otherwise unrelated membership change.
Observed details
- The issue affects the stored Authority Matrix role rules, not table fields or record data.
Thank you.
UPDATE: | FIXED
PASS: the Authority Matrix compatibility repair is live.
Note: I fixed it via the API with a simple AI prompt.
You guys are amazing and the timeliness of the new matrix tool is epic. Teable just keeps getting better and better. THANK You!!!
New permission matrix configuration tool: Export, edit, preview, compare, validate, and apply permissions via CLI with anti-lockout protection.
