AI and Self Hosted question
Hello I am a lifetime user and I am curious how can I use my own AI api key so not rely on credits
Ia self hosted bussines version Sameim cloud version but using my own AI api key
Thank-you
Yes, you can use your own AI API key in Teable.
To set it up:
  1. Go to your Space SettingsAI Settings
  2. Click “+ Add LLM provider”
  3. Enter your provider’s Base URL, API Key, and model names
  4. Configure model preferences and enable the custom model
More details here: Custom AI Model - Teable
Thank you, Gary. I did this, but I am still using my credits :frowning: if I am moving to self-storage. What will be the credit costs?
Thank You
Again
Oh — it might be because you’re using the App Builder. App Builder doesn’t support BYOK yet, but we’re already working on it, and BYOK will be supported in App Builder soon.
If you use self-hosted, all credit usage will go through your own API key, so it’s no longer related to Teable. For now, you’ll need to configure a v0 API key and use a Vercel account to deploy the built app. If you run into any issues with self-hosting, you can refer to this post.
