Right now, this base does not expose an image generation tool to me, so I can’t directly generate images inside the table yet.
I am getting errors like this.
Hi @ankush.thor,
can you please share what you’re trying and what errors you’re getting?
Hi @ankush.thor,
Image generation currently needs to be configured through an AI field.
Could you share how you configured the AI field and where exactly this error appears? We’ll check from there.
There are three columns set up as attachments which show the option to generate AI images, which it is not doing.
I also noticed other models are not available anymore -
Hi @ankush.thor ,
Image generation is a feature of the AI Attachment field. Open the field settings, expand “AI config,” and configure it from there.
Give it a try and let us know if you run into any issues.
