N8n Community Node for Teable — full CRUD, trigger, and AI Agent support
Hey Teable community :waving_hand:
I’ve built and published an open-source n8n community node for Teable: n8n-nodes-teable-io
If you use n8n for automation, this replaces manual HTTP Request nodes with a proper first-class Teable integration.
Install
In n8n go to Settings → Community Nodes → Install and enter:
n8n-nodes-teable-io
Requires n8n ≥ 1.22.
What’s included
Teable node (workflow + AI Agent)
  • Records: Get, Get All, Create, Create Many, Update, Update Many, Delete, Upsert, Search
  • Tables: Get All, Get Schema, Get Views
  • Space / Base: List Spaces, List Bases
  • Dynamic cascading dropdowns — Space → Base → Table → Field loaded live from your API
  • Auto-pagination on Return All (skip/take, up to 100k records)
  • Visual filter builder + raw JSON filter override
  • Works as a tool inside n8n’s AI Agent node
Teable Trigger node
  • Fires on New Record, Record Updated, or New or Updated Record
  • Returns current and previous field snapshots per record so you can see exactly what changed
  • Handles 504s and rate limits gracefully — never gets stuck
Links
Happy to take feature requests or bug reports — either here or as a GitHub issue. Hope it’s useful!
Zacharia (Imperol)
This is awesome — thanks for building this and sharing it with the community! :tada:
