MCP for Cuppy: what would you connect first? 👀
Hey folks! :waving_hand: I’m Pengap from Teable, and I help build Cuppy, our AI agent.
Cuppy already works with external services through our connectors. When a task needs an account connection, you can authorize it right in the conversation.
Now I’m considering another way to extend it: letting you connect your own MCP servers to Cuppy.
If you’re new to MCP, it’s a standard way to make external tools and data available to an AI app. You might already use an MCP server with another AI tool, or your team might have built one for an internal system.
The idea is to make those tools available to Cuppy in your Teable conversations, too.
For example, if your team has an MCP server for checking inventory, you could ask Cuppy to use it alongside your order data in Teable to flag potential shortages.
Would this fill a gap in your workflow? I’d love to hear:
  • Which MCP server would you connect? An existing service or something your team built? A name or public link would help.
  • What would you ask Cuppy to do with it? One concrete task is plenty.
If you’ve tried our current connectors, I’d also love to know what’s missing. Would adding MCP help, or would improving an existing connection make a bigger difference?
This is still a direction I’m exploring, and your examples would help shape what comes first.
An easy way to reply:
I’d connect [MCP server / tool] so Cuppy could [task].
I’d connect our own MCP servers so Cuppy could do the links that connectors can’t: an internal remote MCP over our GTM warehouse (DuckDB), or a Clay workflow we built and exposed as MCP.
Personal wishlist: remote Streamable HTTP with OAuth 2.1 or a PAT, allowlisted per bot and per base, read-only scopes available, and callable from Routines, not just chat.
The opposite works too - Teable as an MCP server. I know there’s no official one, right? We built a remote one on Cloudflare for ourselves. Happy to share if useful.
Keep up the good work!
Non tech user here.
Something like asking via telegram (email or whatever best) for instance “how is this going?” "what documents are missing in this project? “make a report of the project status?”
By the way, this would be for a different person than me, that would have no interest at all at logging in an app created in Teable, so that person would need something that already uses (like telegram or email).
We run a small recruiting agency and a consumer wishlist app on Teable. MCP would help us, but only if Cuppy can act without someone chatting with it. What matters most to us:
  1. Triggers: run Cuppy from Teable automations (new record, field change), on a schedule, or via webhook.
  2. A generic HTTP connector with stored secrets: so we can call any API, even when there is no MCP server for it.
  3. An approval step: before Cuppy writes records or sends anything out (draft, approved, sent).
The MCP servers we’d connect first:
  • lemlist: “When a candidate’s status changes to ‘ready for outreach’, add the matching contacts to our lemlist campaign, skipping anyone already in another campaign.”
  • Recruiterflow (our ATS): “When a form entry arrives, check whether the person already exists in Recruiterflow and link or create the candidate.”
  • Apify: “When a new record with a URL arrives, fetch name, image and price and write them back.” This needs a cost cap per run.
Hey folks! :waving_hand: We shipped MCP support for Cuppy this week, so I wanted to come back and follow up here.
You can now connect your own remote MCP servers and use their tools in your conversations with Cuppy. If you’ve already set one up for another AI tool, or your team has built one for an internal system, you can bring it into Teable too.
You’ll find it under Settings → Integrations → MCPs. There are a few suggested servers to get started with, or you can add your own URL and connect with OAuth or an API key.
And thanks to everyone who shared examples here. I’d love to hear how it goes with an actual task—even if the feedback is “it connected fine, but then I got stuck.” Tell me what you were trying to do, and we can take a look together.
