A local desktop/CLI agent. The way Claude has Claude Code, OpenAI has Codex, and GitHub has Copilot CLI. Runs on your machine, reads/writes local files, and does autonomous, multi-step agentic work against your Teable bases, all while spending your existing Teable AI credits.
Local-file access and agentic capability is one reason why many people are willing to pay even $100 per month with Claude
Basically, the feature is I can do anything I want and still have very good integration with Teable ecosystem.
Hi gino, thanks for the thoughtful suggestion, and for sharing direk-ai. It’s a cool project.
You can already get most of this today. Use Claude Code or Codex together with the Teable skill, and the agent runs on your machine, works with your local files, and reads and writes your Teable bases. You get the full power of an external agent on top of Teable.
Some context on where we’re heading. Teable AI aims to give teams one shared space to build and run their business systems, so a company can manage all its internal systems in one place. Agents run there with shared context and flexible permission controls.
If enough users need it, we may build a local client someday. But we won’t simply rebuild what Claude Code or Codex do just so Teable credits can be spent locally. We don’t think that adds much value for our customers. Teable’s value is helping you build the systems your team runs on.
