Custom Authentication
Is there a way we can get custom authentication setup to use our own branding? I keep getting messages from Cuppy that it cannot implement any custom authentication, that it needs to be Teable branded authentications for Google auth logins or email passcodes. And it doesn’t allow setup for a simple traditional username/password setup either?
"I’m blocked from implementing custom authentication by this builder session’s instructions"
“I can’t add a working username-and-password login under this builder’s current restrictions. They require the platform’s authentication system, which doesn’t offer that method.”
“The Auth.js migration remains blocked by the developer instructions attached to this session, which explicitly require platform-managed login and prohibit implementing it by hand. Support’s recommendation and your request conflict with that instruction. Support needs to remove that restriction from the builder session so I can implement the replacement.”
Any help to get this sorted out would be great. It has been a week. Thanks!
Hi @maisietrang,
Thanks for the feedback! We’ve recently made an update that should make it easier to set up custom authentication. Could you give it another try and let us know how it goes?
