Connect AI tools to Teable with MCP
Teable now has an official MCP server. Connect Claude Code, Codex, Cursor, or any MCP client, and work with your Teable data through conversation, right where you already work.
Connect in a minute
No API token needed. In Claude Code, run:
claude mcp add --transport http teable https://mcp.teable.ai/mcp
Then run /mcp, pick teable → Authenticate, and approve in your browser.
In Codex, add the server, then sign in. The second command opens your browser to approve:
codex mcp add teable --url https://mcp.teable.ai/mcp
codex mcp login teable
For Cursor and other clients, open Settings → MCP in Teable for copy-ready steps. For scripts or CI without a browser, you can use a personal access token instead.
Then just ask
Your AI tool can read and update records, and create tables, fields and views. A few things to try:
  • “Check what we shipped this week and update the roadmap.”
  • “Add every TODO in this repo to our Tech debt table, with the file and line.”
  • “Read this week’s rows in Feedback and write a summary to feedback.md.”
Your permissions, your control
Every action runs with your own Teable permissions. Connected clients show up in Settings → MCP, and you can remove access anytime.
