Can I save or copy a field?
I’d like to use the same field from one table in another table, without having to duplicate the table. Is there an option to save a field?
For single select and multi-select, I want to avoid having to re-type in all the options.
Hi @nani ,
To better understand the request, could you share a more specific use case?
For example, are you trying to reuse the same select options across multiple tables, keep several fields synchronized with the same option list, or quickly duplicate an existing field configuration when building a new table?
For the duplication case, you can also ask Cuppy to help. For example, you can say: “Read this field and create the same field in another table.” It can help inspect the existing field configuration and recreate a matching one in the target table.
