Can you update the Auth Email branding look
Hi @jpoland00 - This is the standard Teable email template. You can ask the chatbot to create a custom template with your preferred design, and it can even send a few test emails to your inbox. It works particularly well if you have your own domain and email address that you’d like to use.
